3 Pages<123>
fredp0275
#11 Posted : Monday, July 14, 2008 10:42:32 PM(UTC)
fredp0275
Hi Gene,
Where is the location of the temperature control harness / temperature control board? and the temperature sensors? I know where is the main control board (on the back of the fridge).
Fred
#12 Posted : Tuesday, July 15, 2008 1:23:47 PM(UTC)
Hi Fred,
The temperature control is #424 on the break down diagram and the temperature sensor (FF) is #242 on the break down diagram. It's located on the side panel in both compartments (behind a small cover).
fredp0275
#13 Posted : Tuesday, July 15, 2008 2:50:33 PM(UTC)
fredp0275
Hi Gene,
Its Fred, I did what you said to unplug the Temp Cont harness and plug it back in and if it started, then the Temp Cont Board need to be replace. So I order the Part 424 today. Thanks for all your help. I have confidence that when I install this part that it will work.:)
Fred
#14 Posted : Tuesday, July 15, 2008 3:20:54 PM(UTC)
Keep us posted.
fredp0275
#15 Posted : Sunday, July 20, 2008 1:32:27 PM(UTC)
fredp0275
Hi Gene,
Its Fred, I have installed the New temp control and i'm a bit disappointed coz, the compressor started and stay on and it is warm I can hold / touch it for awhile, it is not hot. but I still have warm air in the freezer, the ref is still warm. What else could be wrong?
Fred
#16 Posted : Sunday, July 20, 2008 9:42:35 PM(UTC)
Hi Fred,
The compressor is now working.
Next step: why it's not cooling?
I need you to check if the fan next to the compressor and the fan in the freezer are running?
fredp0275
#17 Posted : Tuesday, July 22, 2008 6:55:57 AM(UTC)
fredp0275
Hi Gene,
Yes, the fan ext to the compressor works and the freezer box fan works as well.
Fred
fredp0275
#18 Posted : Tuesday, July 22, 2008 6:57:17 AM(UTC)
fredp0275
Hi Gene,
Yes both fans are running.
Fred
#19 Posted : Wednesday, July 23, 2008 1:33:41 PM(UTC)
Remove the rear cover in the freezer and check how the coil covered in frost. Normally it suppose to be like a light snow.
fredp0275
#20 Posted : Wednesday, July 23, 2008 2:41:25 PM(UTC)
fredp0275
Hi Gene, I dont remember that there is access cover behind the freezer? Its a full Sheet of the entire back of the unit. Is this the cover you are saying? or Are saying a cover inside but in the back of the freezer? Right now it is off, how long it should be on before i can check for symtoms? So, 1.)whats next, if it is normal? 2.) what, if it is has heavy Frost? 3.) whats next, if no frost at all?
Fred
Guest (6)
3 Pages<123>
