Steve Jacobsma
#1 Posted : Tuesday, July 8, 2008 4:50:41 PM(UTC)
Steve Jacobsma
I replaced the tub and bearings on the wash machine. Now it will only go into the fast spin cycle every once and a while. Everything else seems to work just fine.
#2 Posted : Wednesday, July 9, 2008 2:54:46 AM(UTC)
Check all the connectors for a loose pin, if ok, pull out the service sheet and check the timer, soap dispenser magnet, and the door latch.
Steve Jacobsma
#3 Posted : Thursday, July 10, 2008 5:29:18 PM(UTC)
Steve Jacobsma
I checked the pins and they seem ok. I tried another used door latch; no spin. I found a tech sheet but not a service sheet. Are these different?
#4 Posted : Friday, July 11, 2008 1:38:26 AM(UTC)
You will need a meter to check things.
Steve Jacobsma
#5 Posted : Friday, July 11, 2008 4:23:07 PM(UTC)
Steve Jacobsma
I have a multimeter but do not have a lot of experience using it.
#6 Posted : Saturday, July 12, 2008 3:24:40 AM(UTC)
Your data sheet should have a chain circuit to check when spin fails. Just check all the items with the ohm meter, remove power first.
