Lanierb
#1 Posted : 15 years ago
Lanierb
One of the door latches broke, now plate neither rotates nor food heats up .Is there some sort of switch on door that activates these functions? Also where can I get a manual for this microwave?
Joe / APP Team
#2 Posted : 15 years ago
Joe / APP Team
Lanier,
If you have a broken "tang" on the door latch assembly,
The latch is not activating the door switch(s) and the unit will not operate some of the components(depending on which "tang" is broken).
Part number: AP3422263
You will need to dismantle the door to replace the latch, it sounds worse than it is, Really.
It usually involves separating the outer door frame from the metal inner door liner, with a putty knife.
I don't have a transmittable service manual for you to use, someone else here might ?
But , I would reccomend you contact the manufacturer customer service dept. and get it from there.
Good Luck,
Microwave fuse blows out frequently (Microwave Repair)
by Guest 9 months ago
LG LMV1680ST Microwave Door Switches (Microwave Repair)
by ctalbert150 9 months ago
Whirlpool Oven/Microwave combo E1 F2 (Oven Repair (including Ranges and Cooktops))
by MalcolmR 9 months ago
Solved: Removing microwave unit from wall mounted Oven/Microwave combo (Oven Repair (including Ranges and Cooktops))
by MalikR 9 months ago
Whirlpool Gold Accubake Oven/Microwave (Oven Repair (including Ranges and Cooktops))
How to pull microwave out of mw/oven combo (Oven Repair (including Ranges and Cooktops))
by cromking 10 months ago
Microwave goes dead when hot (Microwave Repair)
by Guest 10 months ago
Door Switch Help With Samsung Microwave Model ME21M706BAS (Microwave Repair)
by clagrow 10 months ago
GE PT7800SHASS Combination Microwave / Oven - Key Panel SHORTED (Oven Repair (including Ranges and Cooktops))
by RCAppl 10 months ago
GE Oven - Microwave/Oven PT7800SH2SSA (Oven Repair (including Ranges and Cooktops))
by Guest about a year ago
Kenmore Pizza Oven Microwave (Microwave Repair)
by mwjkmail about a year ago
Kitchenaid (Whirlpool) Microwave door switches (Microwave Repair)
by ForumUser1 about a year ago
Whirlpool Microwave Lower Bulb will not turn on (WMH31017HS08) (Microwave Repair)
by Axtell about a year ago
Kitchen aid electric wall microwave and oven (Microwave Repair)
Frigidaire Microwave PLMVZ169HCA (Microwave Repair)
