Susan
#1 Posted : Wednesday, September 5, 2007 3:33:12 PM(UTC)
Susan
At first sign of a problem, the freezer would thaw. It could easily be fixed by turning the control to off and then turning back on. Pain, but it worked for a while. Now everything in the refrigerator is frozen solid...and the freezer too. Could it be the thermostat, or is it something far worse?
#2 Posted : Wednesday, September 5, 2007 10:50:50 PM(UTC)
Hi Susan
The model number you posted is incomplete.
ltownsend
#3 Posted : Saturday, September 15, 2007 6:28:42 AM(UTC)
ltownsend
This is a standalone refridgerator it freezes everything solid. I can't find the model # in the database. it's about 10 years old.
#4 Posted : Tuesday, September 18, 2007 5:18:32 AM(UTC)
It seems like a fridg. low on refrigerant. Get a tech to look at it.
ltownsend
#5 Posted : Friday, September 21, 2007 5:14:50 AM(UTC)
ltownsend
How do I find a tech?
DerekV
#6 Posted : Sunday, March 29, 2009 1:44:16 PM(UTC)
DerekV
I just started having the same issue. This is a refrigerator only (no freezer section). It is 9 years old next month. Until this point, it has worked perfectly, and there is not a scratch on it. A new one is $200, and the compressor from Sears is $133 (could that be the issue?). I'd like to just fix it myself, but have no way to diagnose it. It runs for a couple of days, then starts to freeze everything, and the thermostat is set to its warmest setting. Kenmore Elite compact refrigerator model #56491499100.
#7 Posted : Sunday, March 29, 2009 7:51:38 PM(UTC)
DerekV
Doubt very much that it would be the compressor.
The original poster had thawing, yours is just getting too cold.
The most likely culprit is the thermostat.
DerekV
#8 Posted : Monday, March 30, 2009 5:27:46 AM(UTC)
DerekV
Thermostat should be inexpensive enough that even if that is not it, it won't be a costly error, right? And it should be easy enough to fix myself. Will it just be the control unit itself inside the fridge, or is there more to it?
#9 Posted : Monday, March 30, 2009 6:13:51 AM(UTC)
No should not be a difficult repair.
Looks like Sear wants $32.01 for it.
They do say this is a substitution but will fit just looks a little different.
Call AppliancePartsPros and see if they can give you a better price.
You unit does not come up online but they should be able to get you the part.
Whirlpool refrigerator freezes everything! (Refrigerator & Freezer Repair)
by Soccergkphillip 5/13/2014 9:17:33 PM(UTC)
Americana Refrigerator Freezes Everything (Refrigerator & Freezer Repair)
by floyd3609 5/29/2012 5:58:09 AM(UTC)
refrigerator freezes everything (Refrigerator & Freezer Repair)
by Charles Scott 2/15/2011 7:57:02 AM(UTC)
