David Peden
#1 Posted : Tuesday, July 8, 2008 1:02:07 PM(UTC)
David Peden
Fridgidaire fridge is freezing food in the fridge compartment.
I have been told it is the temperature control part #5304404821.
Fridge is running for a long time I cannot shut it off with the control in the fridge compartment I have to unplug the unit.
If I leave it off for a few hours the contol knob will work and shut off the unit. I have the freezer compartment control at 1/2. I will plug back in and it will happen again.
Is it the temperature contol unit mal functioning?
If so is it difficult to install a temperature control unit as per above part#
Is there instructions available to change the temp switch
#2 Posted : Tuesday, July 8, 2008 1:27:33 PM(UTC)
Hi David,
Most likely the problem is a bad temperature control. I'm not able to give you more accurate advise because the model number you posted does not come up. Verify and repost it, please.
David Peden
#3 Posted : Tuesday, July 8, 2008 1:35:33 PM(UTC)
David Peden
gene I checked the Model# again the # given is correct 970-618221 is it a Kenmore unit (Sears) I was told manufacturer is fridgidaire kenmore part#46C9705304404821 corresponds to fridgidaire part#530440821 temperature control unit.
hope this helps
#4 Posted : Tuesday, July 8, 2008 4:10:55 PM(UTC)
David,
Is this a Canadian model number?
The temperature control has to be replaced and it should not be too difficult, but I can not verify if the part number is correct because this model number does not come up. Where did you get it from? The name plate inside the fridge or a book?
David Peden
#5 Posted : Tuesday, July 8, 2008 4:16:03 PM(UTC)
David Peden
Gene it is a Canadian Unit I got the model# from the plate inside the fridge.
Not sure if their is any manual or specs to assist in changing?
Dave
Frigidaire Gallery Refridgerator (Dishwasher Repair)
by Guest 6/10/2024 9:18:21 AM(UTC)
Refridgerator keeps running - thermostat bad? (Refrigerator & Freezer Repair)
by PatInPA 4/17/2024 1:53:30 PM(UTC)
Kenmore Elite Refridgerator 795.799773.903 (Refrigerator & Freezer Repair)
by Rick_Titus 10/7/2023 4:28:57 PM(UTC)
Kenmore Elite Refridgerator control panel not working (Refrigerator & Freezer Repair)
by Guest 10/3/2023 10:18:35 AM(UTC)
Whirlpool Refridgerator GD5SHAXLQ02 - Freezer too warm (Refrigerator & Freezer Repair)
by Guest 3/1/2022 11:17:14 AM(UTC)
thermostat issues in maytag refridgerator (Refrigerator & Freezer Repair)
by someguy78 2/26/2022 7:58:31 AM(UTC)
Fridgedaire Refridgerator FRS241 (Appliance Parts)
by Dremcatcr 1/23/2022 11:15:03 AM(UTC)
GE gsh25jfxbww refridgerator (Refrigerator & Freezer Repair)
by David Heath 11/13/2021 4:10:59 AM(UTC)
Whirlpool refridgerator repair (Refrigerator & Freezer Repair)
by HectorMartinez 10/8/2021 12:22:46 AM(UTC)
Whirlpool Refridgerator (Refrigerator & Freezer Repair)
by mikecain01 10/7/2020 3:37:19 AM(UTC)
ge refridgerator not working (Refrigerator & Freezer Repair)
by geno630 9/10/2020 11:57:49 AM(UTC)
Freon leak in Viking refridgerator...repairable? what else can i do? (Refrigerator & Freezer Repair)
by viper_gts 7/29/2020 7:29:30 AM(UTC)
GE Refridgerator model PSS25NGNAWW (Refrigerator & Freezer Repair)
by shuskey450 7/18/2020 9:24:05 AM(UTC)
refridgerator section is not cold enough (Refrigerator & Freezer Repair)
by androidx1 6/8/2020 9:38:34 AM(UTC)
Fan Constantly Running on Viking Refridgerator (Refrigerator & Freezer Repair)
by deeni 4/7/2020 5:09:06 AM(UTC)
