brsummers
#1 Posted : Friday, August 27, 2010 1:23:49 PM(UTC)
brsummers
Dryer will not start. The light does come on in the dryer. Have checked the door switch and I think the thermal fuse. Nothing has checked bad. (ohm good). What else can I check to see why this will not work before checking the motor.
#2 Posted : Friday, August 27, 2010 3:17:24 PM(UTC)
Originally Posted by: brsummers Go to Quoted Post
...I think the thermal fuse...
Make sure you checked the real thermal fuse (#6 on the diagram) for continuity. The normal reading should be close to 0 Ohms.
- The thermal fuse Part number: AP4048636
brsummers
#3 Posted : Friday, August 27, 2010 6:23:49 PM(UTC)
brsummers
Checked this fuse and there was continuity. What is the next thing I check if this part is good?
ThatGuy
#4 Posted : Saturday, August 28, 2010 7:38:06 AM(UTC)
ThatGuy
Groups: Expert
United States
This is your wiring diagram. Wiring information replacement parts for MAYTAG MDE308DAYW Dryer - Ele | AppliancePartsPros.com
I'd check the timer. It could be your motor, it could be a broken wire, it could be missing voltage, or it could be a contact burnt off inside the timer.
Maytag Dryer does not work (Dryer Repair)
by qtlapi 4/22/2015 5:35:13 AM(UTC)
my maytag neptune dryer does not work (Dryer Repair)
by markwarnick@att.net 2/5/2012 11:33:27 AM(UTC)
New Whirlpool Dryer does not work (Dryer Repair)
by Sunshine807 10/11/2011 12:46:25 PM(UTC)
Dryer does not work on medium heat setting (Dryer Repair)
by redcagle 7/28/2011 5:52:53 AM(UTC)
by redcagle 7/28/2011 5:46:49 AM(UTC)
Maytag dryer does not work... (Dryer Repair)
by ringoffire 2/22/2011 4:28:24 PM(UTC)
by glssnb1 1/10/2011 11:04:20 AM(UTC)
Bosch Dryer does not work (Dryer Repair)
by ldonts1 2/15/2008 6:09:56 AM(UTC)
