i recently bought a dryer off of a friend used. i plugged the dryer to outlet and when i hit the start button numerous sparks came out of control panel. i looked at the ground and it was right. but then on the 3 wire area the WIRE ON THE RIGHT side wasnt screwed to the contact. it had turned it black and the dryer no longer works. what do i do to fix it?
You probably have to replace the power cord and check the proper electrical connection of the dryer. Also open the control panel and visually inspect for any damages.
The model number you posted is incorrect. Verify and repost it.
