Dryer will not start. The light does come on in the dryer. Have checked the door switch and I think the thermal fuse. Nothing has checked bad. (ohm good). What else can I check to see why this will not work before checking the motor.
Originally Posted by: brsummers  ...I think the thermal fuse... Make sure you checked the real thermal fuse (#6 on the diagram) for continuity. The normal reading should be close to 0 Ohms. - The thermal fuse Part number: AP4048636
Checked this fuse and there was continuity. What is the next thing I check if this part is good?
Groups: Expert
