jrwright
#1 Posted : Tuesday, August 10, 2010 5:15:26 PM(UTC)
jrwright
The door latch is very lost. It almost drops out. I can work it back in panel and it works but will not stay tight. I think I need Latch assembly - Color: Black**Please note** The manufacturer has now included the latch, handle and switches together
Part Number: AP4264081 made by WHIRLPOOL. Does this come with good instruction to replace old one?
#2 Posted : Wednesday, August 11, 2010 7:47:56 AM(UTC)
I do not know if it does but the following should help.
http://www.servicematters.com/maytag_library/docs/16021814.pdf
Also here is the tech sheet which may be useful in the future
http://www.servicematters.com/maytag_library/docs/16026390.pdf
If you have not already done it, I would open up the door just to be sure that it is a latch mechanism problem.
jrwright
#3 Posted : Saturday, August 14, 2010 7:04:32 AM(UTC)
jrwright
HI,
Thanks for your help. I got the assembly in and it is good. However I'm having trouble disconnecting the wires from the door switches. I do not seem to be able to just pull them apart. Are there something I need to do to make them come out easy?
Rogerr
#4 Posted : Saturday, August 14, 2010 7:08:46 AM(UTC)
I usually take a screw driver, put it between the switch and the connector and then twist the screw driver so it pushes the connector off the switch. Sometimes you have to work one side a little then the other side.
Hope the above makes sense!!
jrwright
#5 Posted : Saturday, August 14, 2010 1:27:20 PM(UTC)
jrwright
Yes this makes sense. I was afraid of breaking the connecton. With those little holes in the prongs I was not sure if I needed to squeeze them together or something to release the prongs.
Roger
Guest (4)
Whirlpool Double Oven - Control Board & Door latch assembly??? (Oven Repair (including Ranges and Cooktops))
by Bhauer 6/6/2017 7:09:43 PM(UTC)
Maytag dishwasher latch assembly (Dishwasher Repair)
by Bark 1/5/2014 6:51:24 AM(UTC)
Replacing latch assembly (Oven Repair (including Ranges and Cooktops))
by hfk0 10/16/2012 10:02:54 AM(UTC)
replacing door latch assembly (Washer Repair)
by JimBradenton 3/23/2012 5:21:14 AM(UTC)
Detergent latch assembly (Dishwasher Repair)
by mikkiblue143 3/11/2012 10:42:50 AM(UTC)
F9 and the latch assembly (Oven Repair (including Ranges and Cooktops))
by nvocc5 12/13/2011 4:38:01 PM(UTC)
Dishwasher latch assembly switches (Dishwasher Repair)
by brabas 6/10/2011 6:01:46 AM(UTC)
latch assembly-Maytag dishwasher (Dishwasher Repair)
by sjjs 2/25/2011 3:42:14 PM(UTC)
Switch stuck in old latch assembly of dishwasher (Dishwasher Repair)
by karenmarie 10/2/2010 8:25:25 AM(UTC)
Latch assembly wire connection (Dishwasher Repair)
by Sneha 9/25/2010 6:53:34 AM(UTC)
door latch assembly (Oven Repair (including Ranges and Cooktops))
by Ratty555 9/16/2010 11:20:54 AM(UTC)
door latch assembly replaceing (Dishwasher Repair)
by johna0721 10/14/2009 10:16:19 AM(UTC)
Dishwasher door latch assembly (Dishwasher Repair)
by Jerry48 10/6/2009 12:50:14 PM(UTC)
Latch Assembly Replacement (Dishwasher Repair)
by NHZ 9/23/2009 3:21:16 AM(UTC)
door latch assembly fell out and I need help! (Dishwasher Repair)
by chellebyerly 5/7/2009 8:54:34 AM(UTC)
