cmalagisi
#1 Posted : Wednesday, June 25, 2008 5:14:09 PM(UTC)
cmalagisi
It doesn't go through the cycles. It will stop before the rinse cycle, then i have to reset it to rinse, but then it will stop before the spin cycle and i have to prompt it again. It is very frustrating because i have to keep going in and switching it to the next cycle. What would make it keep stoping before all 3 cycles are finished?
#2 Posted : Thursday, June 26, 2008 2:53:00 PM(UTC)
It could be a bad lid switch or a bad timer.
In order to provide most accurate advise we need the complete model number of the washer.
cmalagisi
#3 Posted : Thursday, June 26, 2008 3:01:06 PM(UTC)
cmalagisi
The model # is RAX7245JQ0. Thanks
#4 Posted : Thursday, June 26, 2008 4:48:18 PM(UTC)
Unplug the power cord. Open the control panel, unplug the lid switch harness plug and bypass the lid switch (#9 on the break down diagram). Run the washer and see if it'll work properly.
Post the result.
