Originally Posted by: susaniannucci  dryer will not turn on,timer still ticks,on off selection and dryer gets very hot. timer was replaced 5 years ago,fuse was replaced 2 years ago. I get the impression, your dryer does everything but tumble, timer advances, has heat in the tumbler, and stops when the door is opened,is that correct ? If thats the case, you would have a failure in the motor switch circuits(will require a new motor) or a shorted wire harness. I'm just surprised everything else works, I'd expect to have a blown thermal fuse, at the least. :) :confused:
