smylec
#1 Posted : Tuesday, June 24, 2008 3:38:55 PM(UTC)
smylec
I purchased two parts from your company, thinking that the problem that I am having would be resolved, however I am still haveing the problem and don't know what to do. The washer machine fills up with water and overflows, the machine will not agitate, however it will spin. What should I do? The parts ordered was a timer and water level switch. Apparently there was nothing wrong with my original parts and now I am out of money, trying to fix a washing machine. Please help...:(
#2 Posted : Wednesday, June 25, 2008 1:48:52 AM(UTC)
Check the bowl on the side of the washer where the plastic hose goes from the water level switch. See if there is a buildup of soap residue. If so, dump some vinegar in the tub, let sit for a while, then blow in the plastic hose to blow it out. Also, if you have to turn the water supply valves off to stop the flood, you have a bad washer water solenoid.
Post results.
rcyr
#3 Posted : Saturday, July 5, 2008 10:34:55 AM(UTC)
rcyr
SOMEBODY PLEASE HELP i'M NOT VERY GOOD ON THE COMPUTER - HOW THE ***** DO i POST A GUESTION ON THE FORUM FOR A BROKEN DOWN KENMORE THAT WON'T SPIN OR AGITATE BUT WILL KEEP DRAINING FOREVER WHEN KNOB IS TURN TO LAST SPIN CYCLE.
iF THIS GETS THROUGH MY EMAIL IS RICKSROCKWORKS@YAKOO.COM
ps hOW COME i'M NOT SEEING A POST HERE.
whirlpool washing machine model wtw57esvw0 (Washer Repair)
by Guest 5/7/2024 7:57:17 AM(UTC)
Help! Washing machine on repeat rinse cycle (Washer Repair)
by cali.poppy 4/29/2024 9:08:28 AM(UTC)
Frigidaire Affinity Washing Machine - Leaking only sometimes (Washer Repair)
by omf_24 2/24/2024 4:45:41 PM(UTC)
Stem question about Naytag 2-belt washing machine (Washer Repair)
by Hotrodjohn71 1/2/2024 7:50:48 AM(UTC)
Maytag Oasis HE Washing Machine (Washer Repair)
by Guest 12/8/2023 12:55:45 PM(UTC)
Whirlpool Washing Machine won't start/fill (Washer Repair)
by greekguy7 12/8/2023 4:53:34 AM(UTC)
whirlpool model wtw7300dw2 washing machine (Washer Repair)
by Guest 11/8/2023 9:27:17 AM(UTC)
MVWB965HC0 Washing Machine - Need Service Manual or Video to Replace Touchpad and Control Assembl (Washer Repair)
by Guest 10/30/2023 8:11:10 PM(UTC)
Best vintage, American made washing machines (Washer Repair)
by Guest 10/30/2023 5:27:34 AM(UTC)
Washing machine not washing clothes properly (Washer Repair)
by Guest 9/20/2023 11:56:24 AM(UTC)
Washing Machine fill with water but will not spin, rinse or agitate. (Washer Repair)
by jmaiso 9/1/2023 7:04:07 AM(UTC)
Washing machine do not complete the cycle (Washer Repair)
by Guest 8/16/2023 10:02:15 AM(UTC)
Mayag washing machine - possibly locked motor? (Washer Repair)
by crp0499 5/19/2023 3:02:19 AM(UTC)
Recommended replacement for WP22001311 Maytag Washing Machine Unbalance lever (Washer Repair)
by Guest 4/29/2023 12:17:37 PM(UTC)
Whirlpool washing machine drive hub (Washer Repair)
by Guest 4/23/2023 7:29:26 AM(UTC)
