3 Pages123>
markcongdon
#1 Posted : Wednesday, August 4, 2010 9:31:48 AM(UTC)
markcongdon
dryer works fine but no heat? Keeps blowing the T.C.O I have put 1 new one on and it blow in about 20 min. Thanking it is the P.C.M. Does this sound right to you? Thank you.
Joe / APP Team
#2 Posted : Wednesday, August 4, 2010 10:43:21 AM(UTC)
Joe / APP Team
At this time no, the PCB is the least likeliest problem.
You need to check and make sure the exhaust pipe(in dryer), the lint filter,blower area, and the exhaust vent(in the wall),is not clogged or restricted with lint, check for kinked collapsed flex vent or crushed vent hood,etc .
Then check for a shorted heater element or wire to the element.
When you replace the TCO, you should also replace the hi limit thermostat(manufacturer reccomended procedure).
Part number: AP4045617
Part number: AP4045367
You'll most likely find a vent or exhaust problem(in most cases) but you still need to repalce both thermostats.
markcongdon
#3 Posted : Wednesday, August 4, 2010 9:27:25 PM(UTC)
markcongdon
Thanks Joe, I just replaced the vent with solid all new. The blue wire is unpluged from the tco and the pcb and i have contonuaty to ground and about 1.5vac with dryer pluged in none with unpluged. short in wire?
P.S I do not spell very well I am very sorry. Thank You
markcongdon
#4 Posted : Wednesday, August 4, 2010 9:31:05 PM(UTC)
markcongdon
No Short in heater element also it reads 12ohms
Joe / APP Team
#5 Posted : Thursday, August 5, 2010 5:16:57 AM(UTC)
Joe / APP Team
You did great,
Your element is good.
But, the blue wire is shorted somewhere in the harness or the cabinet frame.
My guess is, it's somewhere near the heater or exhaust pipe, but that's only a guess.
Shorted wires are the hardest thing to find in an appliance(unless the harness is burnt or has obvious damage).
And remember, to replace both thermostats, when you repair the machine.
Good Luck;)
markcongdon
#6 Posted : Thursday, August 5, 2010 11:59:03 AM(UTC)
markcongdon
Thanks Joe you have been a big help. Mark L Congdon
You did great,
Good Luck;)
Joe / APP Team
#7 Posted : Friday, August 6, 2010 6:21:05 AM(UTC)
Joe / APP Team
You're quite welcome,
Let us know how things went.:cool:
markcongdon
#8 Posted : Friday, August 6, 2010 12:29:54 PM(UTC)
markcongdon
Hey Joe can you tell me how much volts ac are at the T.C.O from the P.C.B Thank you.
Joe / APP Team
#9 Posted : Friday, August 6, 2010 2:04:59 PM(UTC)
Joe / APP Team
AC voltage from the PCB to the TCO is 120 volts on the blue wire, with the machine running in a heat mode.
Did you find something else ?
:confused:
markcongdon
#10 Posted : Friday, August 6, 2010 2:21:20 PM(UTC)
markcongdon
No Just thought 120v might be high that is what i have thanks alot Joe you have been a big help. Mark L Congdon:)
Guest (6)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
no heat from oven or broiler (Oven Repair (including Ranges and Cooktops))
by lennyag 1/5/2024 1:41:07 PM(UTC)
Dryer loud squeaking and no heat (Dryer Repair)
by hackerfam 11/2/2023 10:52:15 AM(UTC)
LG Dryer DLE2301R No Heat (Dryer Repair)
by mhess01 10/19/2023 4:56:37 PM(UTC)
No heat when assembled (Dryer Repair)
by Guest 8/16/2023 3:44:03 AM(UTC)
whirlpool PN# W10339417; no heating after replacing element (Oven Repair (including Ranges and Cooktops))
by Guest 7/13/2023 12:27:07 PM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
No heat, (Dryer Repair)
by tseibring 1/8/2023 7:57:44 AM(UTC)
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 11/24/2022 7:24:02 PM(UTC)
Gas Dryer GE GFDS355GL0MS No Heat. Ignitor is good E11 error. (Dryer Repair)
by jim.starzynski@gmail.com 7/5/2022 6:35:29 PM(UTC)
Dryer starts, does not stop, no heat (Dryer Repair)
by Guest 6/28/2022 11:03:33 AM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 5/18/2022 8:22:27 PM(UTC)
heeat turns on no heat comming up through floor register (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 2/6/2022 2:57:49 PM(UTC)
3 Pages123>
