lylefjones@hotmail.com
#1 Posted : Wednesday, August 4, 2010 7:29:26 AM(UTC)
The water keeps running through all cycles the only way to stop it is to close the valve and it's a pain running back and forth to turn the water on for each cycle that needs water. I would like to fix it myself but am not sure where to start.
ThatGuy
#2 Posted : Wednesday, August 4, 2010 7:37:32 AM(UTC)
ThatGuy
Groups: Expert
United States
A quick test. Turn the water on. Unplug the washer. Does the water stop? Or does it keep coming in? If it keeps coming in, you have a water valve that is stuck open and its needs to be replaced. If you can provide your model no. we can help with the part number.
water won't stop running into ice maker (Refrigerator & Freezer Repair)
by mayfair1031 10/14/2016 8:45:50 AM(UTC)
KitchenAid Superba Ice maker water won't stop running and is overflowing! (Refrigerator & Freezer Repair)
by jhschlak 12/4/2011 3:53:26 PM(UTC)
Water won't stop running (Washer Repair)
by SugarSugar 12/1/2011 7:54:45 AM(UTC)
Water won't stop running even during agitation (Washer Repair)
by AliciaD 7/7/2010 10:22:30 AM(UTC)
water won't stop running (Washer Repair)
by lilladyofhouse 3/30/2010 11:18:15 AM(UTC)
Washer machine water won't stop running (Washer Repair)
by jrciii 10/21/2009 3:15:42 PM(UTC)
Cold water won't stop running on my Whirlpool Top Loading Washer! (Washer Repair)
by tm3191951 10/17/2009 2:43:34 PM(UTC)
Hot water won't stop running into washer (Washer Repair)
by roseblock 7/1/2009 1:05:52 PM(UTC)
