Ok here goes, water will not shut off filling the icemaker. I replaced to dual water inlet solenoid twice..2 brand new parts...still leaks. Purchased a new ice maker and still the water will not shut off. The inside of my side by side freezer looks like an ice cave. What's next?
Groups: Expert
If you unplug the fridge, does the water still leak inside?
I have replaced complete ice maker including water valve and turned everything back on . Runs water into tray and continues until you shut off water . Anyone know what the problem might be. Thanks
Mayfair 1031 did you fix your ice maker problem?
