hsking
#1 Posted : 15 years ago
hsking
Hi. I need some help here. My dryer will run for around 2-3 minutes and then shuts off. almost seems like it is getting too hot. I bought a new motor and vent fan, replaced them both and it is still doing the same thing. any suggestions?
Thanks,
Scott King
Joe / APP Team
#2 Posted : 15 years ago
Joe / APP Team
Thanks,
Scott King
Scott,
When you replaced the motor and blower fan,
Did you check the drum rollers, idler pulley and front slides for debris or damage,worn belt,causing excess drag on the motor ?
You may have a voltage supply problem ?
Being an electric dryer, you need to maintain a constant, minimum voltage of 105 volts on both legs of the power cord,when the dryer is started(motor surge)and or running. (amps will surge up to as much as 15 to 18 amps at surge and drop to 3 to 4 amps when motor is in run mode).
Do you have a meter(s) to test voltage and amperage at the power cord when the dryer is attempting to start or running ?
That's where I would start, after replacing the parts you have, and still having the same problem.
Need Help..... (Washer Repair)
by roblee 14 years ago
Need help...Oven shorted :( (Oven Repair (including Ranges and Cooktops))
by Dre 14 years ago
need help.... (Dishwasher Repair)
by tirra 16 years ago
Need help....won't start (Dryer Repair)
by careymsv 17 years ago
