Teddyk
#1 Posted : Wednesday, June 18, 2008 12:55:42 PM(UTC)
Teddyk
:confused: Washer will fill,agitate,drain, BUT no spin, then on rinse, will fill, agitate,drain, AND still no spin..Motor runs, belt and pulleys turn freely, but tub seems to be very tight...Any & all suggestions appreciated..Thanks,Ted..
#2 Posted : Thursday, June 19, 2008 4:03:36 PM(UTC)
The first thing I would check is any foreign objects (small gourmets like a sock) between the inner and outer tubs.
Also check the belt condition.
Here are the break down diagrams for the Maytag washer Model MAV6357AWW
Teddyk
#3 Posted : Thursday, June 19, 2008 5:46:45 PM(UTC)
Teddyk
Gene, Thanks a bunch for your reply..I also suspected restriction between inner & outer tubs, but inspection space is less than 1/2", so I removed upper ring & seal on outer tub, agitator, & the 4 1/2" stud bolts in bottom of inner tub...I need to remove inner tub, but can't figure that removal out! How do you get that sucker out?? I made a post earlier today asking that?? The belt is in good shape and seems snug..Thanks again, Ted
#4 Posted : Friday, June 20, 2008 3:56:43 PM(UTC)
Hi Ted,
You can find the complete instructions in the Service manual.
2pleach
#5 Posted : Thursday, October 15, 2009 6:26:34 PM(UTC)
2pleach
Hi Ted,
I had similiar issue. My Maytag Neptune TL FAV6800AWW stopped spinning as well. I used the test mode to determine if the error codes could identify what the issue was, but nothing irregular. Just the error codes that I caused while attempting to test: 22, 18, d. But nothing related to the spin. So, I had determined that tumbler was good, water pump was good, but would not spin in spin cycle. I determined this by popping the lid during the cycle. It tried to spin, but something seemed to have prevented it from continuing.... I had called Sears but they wanted to charge $139 just for the visit. After reading the forums, everything pointed to the Clutch. So, the question was do i need just the Clutch or the Clutch and Pulley. I went to Appliance Parts store in AZ, i asked them to pull both parts... When we pulled both parts out, they were identical.. Just the Clutch was $80, the Cluth and Pulley was $160. The only difference besides pricing was the more expensive model had the instructions and a screw... So, i bought the less expensive one (WH25001169 M Clutch) and the sales guy copied the 2 page instructions for me... Easy installation for clutch.. You just need to loosen the tension bolt on the motor and that will give some slack on the belt and u can swap out the clutch very easy. You don't have to remove the shaft from the inner and out tub if you don't want to... I left it alone since it was not leaking and working fine. All I did extra was remove the plastic tumblers from the inner tub just to clean...it definitely needed a good cleaning after 5 yrs of usage. After putting everything back together, I ran a spin cycle to make sure nothing mechanically is wrong. After that, I ran 2 quick wash to check for leaks...After everything checked out, I put it all back together and the wife is back in business with the laundry. In all, it cost me $85 and my time... If I had a repaire man to do it, your looking at maybe $500 where $80 would have been extra in his pocket becuase he would have billed me for the higher priced part. Good luck and hope this helps.
Maytag washer will not spin after the rinse cycle (Washer Repair)
by kempf25 3/31/2011 9:12:12 AM(UTC)
Maytag Washer will not spin. How do you bench test the hall effect sensor on the mot (Washer Repair)
by electrotec 12/23/2009 5:34:12 AM(UTC)
