tina stanfield
#1 Posted : Tuesday, June 17, 2008 10:35:10 AM(UTC)
tina stanfield
My washer will drain but will not spin. Someone told me it was the transmission and I wanted to know if this is correct.
abbie
#2 Posted : Wednesday, June 18, 2008 5:05:38 AM(UTC)
abbie
I would say it is the drive coupler. It a small part that drives the transmission.It,s not expensive and would be worth fixing.
shartang73
#3 Posted : Wednesday, June 18, 2008 6:26:29 AM(UTC)
shartang73
Mine did the same thing and they said its called the "Wig-Wag" part?
abbie
#4 Posted : Wednesday, June 18, 2008 5:18:02 PM(UTC)
abbie
TINA,S washer is not a belt drive,so there is a coupling that runs the gear case.On your washer the wigwag controls the spin/drain on one side of the coil and the agitation on the other side.On Tina washer there is no wigwag.On Tina direct drive washer the COUPLING RUNS THE SPIN CYCLE AND THE AGITATION CYCLE.
whirlpool washer will only agitate on gentle (Washer Repair)
by marycwells@gmail.com 5/8/2024 7:09:34 PM(UTC)
Whirlpool washer noise for new washer (yes under warranty) (Washer Repair)
by Huntersdl 4/30/2024 3:01:43 PM(UTC)
whirlpool washer model WFW6620HW2 Fried? (Washer Repair)
by justme56 2/11/2024 8:42:17 AM(UTC)
Whirlpool washer F20 code (Washer Repair)
by wstrick14 1/6/2024 3:42:34 PM(UTC)
Whirlpool washer clicking when filling (Washer Repair)
by RogeM 12/3/2023 8:13:49 AM(UTC)
Whirlpool washer spin cycle towels only problem (Washer Repair)
by kylo67 10/1/2023 5:54:44 PM(UTC)
Noise and wobble during spin cycle in top load Whirlpool washer (Washer Repair)
by Guest 8/19/2023 5:31:59 AM(UTC)
Whirlpool washer Not spinning 6/21/23 (Washer Repair)
by yveron 6/21/2023 11:33:50 AM(UTC)
whirlpool washer buzzer Way too loud! (Washer Repair)
by Guest 5/1/2023 11:33:43 AM(UTC)
whirlpool washer wt5057lo powers on but won't start (Washer Repair)
by Guest 4/20/2023 4:19:14 PM(UTC)
Whirlpool washer spins during drain cycle (Washer Repair)
by jsdscot 1/23/2023 5:04:07 PM(UTC)
Whirlpool Washer WTW5105HW1- Loud Spin Cycle- Spring/suspension question (Washer Repair)
by gabeTBP 1/21/2023 6:26:31 AM(UTC)
No Hot Water in Whirlpool Washer (Washer Repair)
by Billpa2023 1/4/2023 12:12:44 PM(UTC)
whirlpool washer fill and drain only (Washer Repair)
by Randero 10/14/2022 2:53:13 AM(UTC)
Capacitor for Front Load Whirlpool washer Model # wfw9550ww00 (Washer Repair)
by Guest 9/11/2022 2:49:05 PM(UTC)
