207 Pages«<9596979899>»
#961 Posted : Saturday, July 24, 2010 2:26:51 PM(UTC)
mloborny
#962 Posted : Saturday, July 24, 2010 2:47:54 PM(UTC)
mloborny
Gene, can you tell me where exactly the thermistors are located in the unit? It's hard to tell on the diagram where they are.
#963 Posted : Saturday, July 24, 2010 2:52:49 PM(UTC)
The only thermistor you need at this time is located on top of the evaporator coil (#241 on the diagram).
mloborny
#964 Posted : Saturday, July 24, 2010 2:58:54 PM(UTC)
mloborny
Thanks so much, I saw it on the diagram, now I know where to shine the flashlight :) I'll keep you posted.
kcofoid
#965 Posted : Monday, July 26, 2010 10:36:00 AM(UTC)
kcofoid
The right (refrigerator) temperature control is actually the thermostat which reads the refrigerator temperature, while the left (freezer) temperature control controls the cold air flow from the freezer into the refrigerator. Setting this temperature control "as cold as possible" means you almost closed the cold air access into the refrigerator.
Set the freezer temperature control on 1 and wait about 24 hours to see the result.
Dear Gene: I wanted to make sure I tried everything you said to do before replying back on the GE refrigerator with cold freezer and warm refrig. I currently have the temp and refrig settings on 5. The freezer is at 10 degrees and the refrig is at 44 degrees for the past 2 days. I removed the back panel in the freezer and the coils are ice free. I could not find the defrost heater to check continuity on it. ( but with the coils being ice free I assume it is probably ok ) Does this point to the need for a new control for the refrig?? Sorry for the delay but I wanted to try everything that I could do based upon your description.. Thanks KEnt
#966 Posted : Monday, July 26, 2010 4:56:44 PM(UTC)
Quote:
...I removed the back panel in the freezer and the coils are ice free...
How about some thin snow?
If the coils are clean, there is a problem with the sealed system. Very likely it is low on Freon. It has to be tested by a pro.
kcofoid
#967 Posted : Monday, July 26, 2010 6:02:18 PM(UTC)
kcofoid
coils are clean ( already checked).....thank you for your patience with me and the advice. I now know what I need to do
mloborny
#968 Posted : Monday, July 26, 2010 6:08:52 PM(UTC)
mloborny
Gene, re: the warm fridge cold freezer you were assisting me with. You referred me to page 3 for instructions. We found that the heater is definitely bad, and I am now trying to check the defrost thermostat. It has zero ohms at room temperature. Is it supposed to be open or closed at room temp? My model was GE GSS22JFMDCC
poliepolie
#969 Posted : Tuesday, July 27, 2010 12:19:54 PM(UTC)
poliepolie
Originally Posted by: jeffrey_benjamin Go to Quoted Post
Seems to me your refrigerator is low on refrigerant, indicating a leak in the sealed system. This leak will have to be located, repaired, & regassed. This has to be done by a qualified technician.:(
Any idea of what the avergae cost of such repair would be?
Sears wants $75 just for coming out or $252 for 1 year extended warranty (of service and repairs). They won't tell me the cost of fixing a leak and refilling the refrigerant.
#970 Posted : Tuesday, July 27, 2010 5:55:46 PM(UTC)
I would never deal with large companies like Sears unless you have to do it because of warranty service.
Much better to call a local repair company because only for a such company you can be a valued customer.
Guest (24)
Freezer is fine, refrigerator is too warm. (Refrigerator & Freezer Repair)
by mrhoagie 11/3/2012 1:46:58 PM(UTC)
Another Freezer is fine, refrigerator is too warm. (Refrigerator & Freezer Repair)
by rzeune 10/7/2010 9:19:39 AM(UTC)
by allemich 4/19/2009 8:02:07 PM(UTC)
