lewmerk
#1 Posted : Thursday, July 22, 2010 1:36:22 PM(UTC)
lewmerk
I think I've messed up the temperature sensor after putting out a grease fire on my old Tappan. The gas ignites but the control doesn't control. Just gets really hot.
Is this a civilian-replaceable part?
If I have to pay someone I might as well get a new range.
And there's also the question of whether I am making the correct diagnosis.
If I buy the part will you give me instructions on installing it?
#2 Posted : Thursday, July 22, 2010 2:35:38 PM(UTC)
What is the complete model number of the oven?
lewmerk
#3 Posted : Friday, July 23, 2010 3:47:29 AM(UTC)
lewmerk
Tappan Model # 30-2272-00/03
#4 Posted : Friday, July 23, 2010 2:18:40 PM(UTC)
There is no a separate oven sensor in this oven. The temperature controls by the oven thermostat (#12 on the diagram).
Looks like the thermostat has been damaged and has to be replaced. In order to do it you have to remove the top panel which is secured to the burners by the three screws around each burner.
- The oven thermostat Part number: AP4358457
lewmerk
#5 Posted : Saturday, July 24, 2010 8:27:09 AM(UTC)
lewmerk
Thanks. I think I might get it done right but on closer inspection I think I'd be better off replacing the whole range. I use it a lot and it probably has reached the end of its useful life. Besides I have a hankering for convection, timed baking and a clock that works.
Thanks for your help.
Lew
#6 Posted : Saturday, July 24, 2010 1:50:47 PM(UTC)
You are welcome Lew. Good luck with a new range.
Whirlpool RBS305PDB1 wall oven temp control (Oven Repair (including Ranges and Cooktops))
by WPoven 3/28/2022 7:14:02 PM(UTC)
Oven temp control (Oven Repair (including Ranges and Cooktops))
by woodman46 9/9/2014 10:50:18 AM(UTC)
Westinghouse Oven Temp Control & Model Question (Oven Repair (including Ranges and Cooktops))
by Mark_in_Seattle 8/28/2010 12:05:47 PM(UTC)
Need new oven temp control (Oven Repair (including Ranges and Cooktops))
by WayneDeLisle 11/10/2009 9:27:11 AM(UTC)
Oven Temp Control Problem (Oven Repair (including Ranges and Cooktops))
by tfarrill 10/21/2009 6:50:30 PM(UTC)
Gas GE Oven temp control knob spinning? (Oven Repair (including Ranges and Cooktops))
by Hokies_fan 7/2/2009 4:24:21 PM(UTC)
Increase oven temp control not working (Oven Repair (including Ranges and Cooktops))
by fioman6740 4/25/2009 8:06:55 PM(UTC)
Whirlpool oven temp control (Oven Repair (including Ranges and Cooktops))
by olivia 10/28/2008 10:50:05 AM(UTC)
by fred1329 9/15/2007 8:33:13 PM(UTC)
