I need a new oven tempurature control for a Westinghouse wall oven, Model OK21HXO, serial # ME80542 .
The old one has a power lug that is burnt off.
I can post pics if it will help.
Any help would be greatly appreciated.
TIA
Wayne
Wayne,
The model number you posted does not come up, probably due to its age. If you have any numbers from the old part, post them and it might help to find a replacement part.
Gene. Hey, thanks for the quick response. I removed the control and got the following #'s off it. On The top end is printed 021577, On the bottom end is printed 070177 The thermostat mounting plate is stamped: QE 162224 TYPE B 240V 30A 06-30-77 There appears to be something printed on the front plate but it isn't readable. The thermostat is removable from the back of the control housing by 4 screws. Pretty simple and straight forward design. Doesn't look repairable, the Bakelite housing is badly burned on one side where the line in connects. Hope this helps identify it. TIA, Wayne
Wayne,
I found the part number for this oven thermostat, but unfortunately this part has been discontinued and is no longer available. The part number is 530016222.
Ok, thanks Gene. I appreciate the assistance.
Wayne
Gene. I just got a hit from another board with the P/N 5300162224. Does this # compute? Wayne
Wayne,
I'm sorry, it was mistyping. The correct part number is 5300162224 and it is no longer available.
Gene. No problem. With the help of a friend, I was able to cross reference the P/N and actually find a picture of it. I have located 2 used parts, and what I think is a NOS part. Looks like I'll get it fixed after all. Again, thanks for your help. Wayne
You are welcome. An aftermarket or a used part can be a good solution. Keep us posted.
Originally Posted by: Gene  You are welcome. An aftermarket or a used part can be a good solution. Keep us posted.
Gene. I found a cross-reference #, P/N 5450-224. My problem is that I haven't been able to contact 3 different resellers, they don't answer the phone or e-mails. I found a seller on ********** that has 7 units, I HATE **********, but I guess I'll have to try that. Wayne
