AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Whirlpool Gold Senseon Ultimate Care II Dryer shutting off!!
I need help,Wife wants a new dryer but the one I have looks great but I'm running into a problem. The dryer Whirlpool Model # GEQ9858JQ0 ,shuts off after running several minutes, it started on the dryel setting and then it did it on the medium setting, now I'm down to just the light setting but it does get them dried on that setting. I'm not sure is its a board or the thermal couplings. Help, I can fix it but I need to know what part is causing the problem. Any help would be greatly appreciated.
THIS FORUM IS DEAD!!!!!!! |
No as soon as it turns off, I can reset it and it will start right back up and run for 5-15 minutes then do it again. So far the only setting that it will not do this is the low setting.
I would check the thermistor. See Page 5 in the tech sheet. |
Dryer Repair
