kabowabo1
#1 Posted : 15 years ago
kabowabo1
I replaced the evaporator fan in the freezer and it works good. Now the fridge is only cooling to 45 degrees. What could be wrong? Before replacing the fan in freezer, the fridge was cooling around 38, and the temp control was not turn down all the way.
#2 Posted : 15 years ago
Measure the freezer temperature and post.
kabowabo1
#3 Posted : 15 years ago
kabowabo1
The freezer is at 8 degrees
#4 Posted : 15 years ago
Freezer seems ok, why did you replace the fan motor? Check that the fan is blowing air and turning in the right direction. Also, check for a ice clog in the lower return vent.
Amana fridge warm, freezer cold (Refrigerator & Freezer Repair)
by agdodge4x4 about a year ago
Fridge warm, freezer cold, evaporator covered in ice (Refrigerator & Freezer Repair)
by adrianvm about a year ago
GE GTS18GSSHMRSS Fridge Warm, Freezer Cold (Refrigerator & Freezer Repair)
by Pete Pliers 2 years ago
Whirlpool wrx735sdbe00 - Fridge warm no ice (Refrigerator & Freezer Repair)
by old_school33 3 years ago
Fridge warm, freezer is fine - Can it be the dampers if they pass the diagnostics? (Refrigerator & Freezer Repair)
by ocjk 4 years ago
Amana ABB2224WEB2 freezer and fridge warm (Refrigerator & Freezer Repair)
by aefbae 4 years ago
Freezer cold, Fridge Warm Kenmore 253.60082411. Model doesn't have timer (Refrigerator & Freezer Repair)
by jhmon 5 years ago
Freezer works, Fridge Warm (Refrigerator & Freezer Repair)
by cpb521 5 years ago
Freezer Stopped Working, Fridge Warm As Well (Refrigerator & Freezer Repair)
by Desi4881 6 years ago
fridge warm, replaced locked down evaporator fan (Refrigerator & Freezer Repair)
by dtmeyer 7 years ago
Whirlpool Defrost not working and freezer and fridge warming up (Refrigerator & Freezer Repair)
by kimberdesi 8 years ago
Maytag WFF2557HEB French Door, Freezer and Fridge Warm (Refrigerator & Freezer Repair)
by Agent0071 8 years ago
Fridge warm, ice only between sides (Refrigerator & Freezer Repair)
by Itallbreaks 9 years ago
Freezer cold, fridge warm Whirlpool (Refrigerator & Freezer Repair)
by Debma 9 years ago
Samsung RS261MDWP fridge warm/freezer cold (Refrigerator & Freezer Repair)
by Rchcraft9 10 years ago
