kabowabo1
#1 Posted : Sunday, July 4, 2010 7:56:00 PM(UTC)
kabowabo1
I replaced the evaporator fan in the freezer and it works good. Now the fridge is only cooling to 45 degrees. What could be wrong? Before replacing the fan in freezer, the fridge was cooling around 38, and the temp control was not turn down all the way.
#2 Posted : Monday, July 5, 2010 2:50:42 AM(UTC)
Measure the freezer temperature and post.
kabowabo1
#3 Posted : Monday, July 5, 2010 8:00:40 AM(UTC)
kabowabo1
The freezer is at 8 degrees
#4 Posted : Tuesday, July 6, 2010 12:42:17 AM(UTC)
Freezer seems ok, why did you replace the fan motor? Check that the fan is blowing air and turning in the right direction. Also, check for a ice clog in the lower return vent.
Amana fridge warm, freezer cold (Refrigerator & Freezer Repair)
by agdodge4x4 12/25/2023 6:22:47 PM(UTC)
Fridge warm, freezer cold, evaporator covered in ice (Refrigerator & Freezer Repair)
by adrianvm 10/14/2023 10:45:13 AM(UTC)
GE GTS18GSSHMRSS Fridge Warm, Freezer Cold (Refrigerator & Freezer Repair)
by Pete Pliers 4/19/2023 4:41:06 PM(UTC)
Whirlpool wrx735sdbe00 - Fridge warm no ice (Refrigerator & Freezer Repair)
by old_school33 6/10/2022 2:29:09 PM(UTC)
Fridge warm, freezer is fine - Can it be the dampers if they pass the diagnostics? (Refrigerator & Freezer Repair)
by ocjk 6/23/2021 7:39:39 PM(UTC)
Amana ABB2224WEB2 freezer and fridge warm (Refrigerator & Freezer Repair)
by aefbae 12/30/2020 10:38:33 AM(UTC)
Freezer cold, Fridge Warm Kenmore 253.60082411. Model doesn't have timer (Refrigerator & Freezer Repair)
by jhmon 5/29/2020 12:20:04 AM(UTC)
Freezer works, Fridge Warm (Refrigerator & Freezer Repair)
by cpb521 12/18/2019 6:11:02 AM(UTC)
Freezer Stopped Working, Fridge Warm As Well (Refrigerator & Freezer Repair)
by Desi4881 5/26/2019 1:09:05 PM(UTC)
fridge warm, replaced locked down evaporator fan (Refrigerator & Freezer Repair)
by dtmeyer 1/6/2018 9:23:36 PM(UTC)
Whirlpool Defrost not working and freezer and fridge warming up (Refrigerator & Freezer Repair)
by kimberdesi 9/13/2017 12:37:45 PM(UTC)
Maytag WFF2557HEB French Door, Freezer and Fridge Warm (Refrigerator & Freezer Repair)
by Agent0071 10/18/2016 7:13:59 AM(UTC)
Fridge warm, ice only between sides (Refrigerator & Freezer Repair)
by Itallbreaks 7/2/2016 7:29:32 PM(UTC)
Freezer cold, fridge warm Whirlpool (Refrigerator & Freezer Repair)
by Debma 1/25/2016 11:09:49 PM(UTC)
Samsung RS261MDWP fridge warm/freezer cold (Refrigerator & Freezer Repair)
by Rchcraft9 7/31/2015 6:08:29 PM(UTC)
