geranium
#1 Posted : Thursday, July 1, 2010 8:15:02 AM(UTC)
geranium
I have a kitchen aid dishwasher and can`t figure out if the control panel is broken or the control board is broken. I have flashing lights on the control panel after a wash. I unplugged the unit and when I plug it back in they begin flashing again...when I try to cancel it then the cancel button flashes. Can you please help me figure this out? :confused: Thanks, Cathy
#2 Posted : Thursday, July 1, 2010 11:02:32 AM(UTC)
Cathy,
Do the following test:
1. Unplug dishwasher or disconnect power.
2. Open the dishwasher door.
3. Open console and disconnect the keypad ribbon connection from the control (at P1). Make sure all other connections are made.
4. Put console back together. Do not close the dishwasher door.
5. Plug in dishwasher or reconnect power.
6. Wait 5 seconds.
7. Close dishwasher door.
8. Monitor the control’s response:
a) If the control is OK (no longer sees shorts with the keypad
unplugged), it will respond by turning on a Drain Motor for
2 minutes. Replace the console assembly if the control responds OK
b) If the control is not OK (still sees shorts with the keypad unplugged), then the drain motor will NOT respond and will remain off. If no response, replace the control.
- The control board Part number: AP4309110
If you need the correct part number for the console assembly, post the color of it.
geranium
#3 Posted : Thursday, July 1, 2010 8:31:00 PM(UTC)
geranium
Hello Gene thanks for your response. I Ran the test you gave me and the motor ran for 2 mins so I`ll need the console assembly...The color is stainless steel. If you can post the correct part number, that would be helpful as well.
Thank you again,
Cathy:D
#4 Posted : Thursday, July 1, 2010 8:59:04 PM(UTC)
You are welcome Cathy.
The console Part number: AP4308884
Gene,
Could someone please help me fix my washer (Washer Repair)
by HopelessNKY 7/28/2022 3:00:04 PM(UTC)
KitchenAid Artisan unknown problem. Please help! (Blender Repair)
by fakupos 5/17/2022 8:00:10 AM(UTC)
Please help me diagnos refrigerator not cooling (Refrigerator & Freezer Repair)
by beaverislander 1/1/2022 6:18:12 AM(UTC)
please help kitchen aid fridge noise (Refrigerator & Freezer Repair)
by marcelmcesar 8/3/2021 4:54:39 PM(UTC)
Admiral ss fridge freezer damper door freezing open Please help (Refrigerator & Freezer Repair)
by swingbyte 4/1/2021 11:35:24 PM(UTC)
Fisher & Paykel DEIX2 Dryer Keeps tripping t-stat Please Help (Dryer Repair)
by hotlicksexhaust 5/7/2020 8:22:39 AM(UTC)
Silence is definitely not Golden (LG) ... Please help (Microwave Repair)
by benh1234 1/16/2019 2:13:22 PM(UTC)
Please Help - Whirlpool WFG524SLAS (Oven Repair (including Ranges and Cooktops))
by yozzomp 12/5/2018 1:27:04 PM(UTC)
Cant remove metal tub old Whirlpool/ Kitchen Aide Washer Please Help! (Washer Repair)
by robertgarven 3/23/2018 2:24:04 PM(UTC)
Mystery part loose in box - please help identify! (Refrigerator & Freezer Repair)
by xkandakex 12/14/2017 10:36:27 AM(UTC)
PLEASE HELP! Quiet Partner III Cancel, Rinse Only Lights Blinking (Dishwasher Repair)
by zed40 3/24/2017 6:16:49 PM(UTC)
Please Help,GE Fridge Water not dispensing and other issues. # PSS25MGMAWW (Refrigerator & Freezer Repair)
by c.marvin077 2/11/2017 8:02:28 AM(UTC)
Oven and display not working...please help. (Oven Repair (including Ranges and Cooktops))
by LJ44 2/5/2017 8:12:19 AM(UTC)
Please HELP!!! My dryer is not heating. (Dryer Repair)
by Anonpirate 7/28/2016 11:44:39 PM(UTC)
Please help with my GE replacement motor wiring (Dryer Repair)
by Mjutton 6/29/2016 7:36:12 PM(UTC)
