dryer does not start when turning the start button
What is the complete model number of the dryer?
Originally Posted by: Gene  What is the complete model number of the dryer?
Gene. GLER34IAS2 Model number
Originally Posted by: jrc9275  GLER34IAS2 Model number This is my model number for my frigidaire dryer
Originally Posted by: jrc9275  GLER341AS2 Model number this is the complete model number
Make sure there is power to the dryer. Check the door switch for continuity. If the door switch is good, check for continuity the thermal limiter (#36 on the diagram). - The door switch Part number: AP4316048
Originally Posted by: jrc9275  this is the complete model number thermal switch #2012680444 checks good
Originally Posted by: Gene  Make sure there is power to the dryer. Check the door switch for continuity. If the door switch is good, check for continuity the thermal limiter (#36 on the diagram). - The door switch Part number: AP4316048
thermal limiter checks good #2012680444
Are you sure you checked the right part? The part number you posted does not come up.
Have you checked the power to the dryer and the door switch?
