Water In Door Has A Little Burst And An Instant Later Just A Trickle Of Water Into Glass. Ice Maker Making Very Small Ice Cubes. Water Good To Connection At Wall. Copper Tubing From Wall To Frig. Help !!!
How old is the water filter? It has to be replaced between 6 to 12 months, depends on how much water had been used. - The water filter Part number: AP3859302
Originally Posted by: Gene  How old is the water filter? It has to be replaced between 6 to 12 months, depends on how much water had been used. - The water filter Part number: AP3859302
I tried a new water filter same problem
Had you drained out 2-3 gallons of water from the system after you replaced the filter?
Originally Posted by: alshields  I tried a new water filter same problem the water slowed down befor I changed the filter. yes i drained out the water
Disconnect the dispenser water line under the freezer door at the union connector (#80 on the diagram) by pushing in the center collar while pulling out the tube. Put the end of the tube in a bucket. depress the water dispenser lever and check the water pressure out of the tube. Post the results. Gene.
Originally Posted by: Gene  Disconnect the dispenser water line under the freezer door at the union connector (#80 on the diagram) by pushing in the center collar while pulling out the tube. Put the end of the tube in a bucket. depress the water dispenser lever and check the water pressure out of the tube. Post the results. Gene. THANKS, I GAVE UP AND CALLED GE SERVICE. THE FILTER HOLDER WAS NG ( BLOCKED) . HE ELEMINTED THE FILTER FOREVER. A NEW HOLDER WAS ABOUT $200. WE HAVE GREAT CITY WATER !
You are welcome. I'm glad the problem solved and you are back in business.
