alshields
#1 Posted : 15 years ago
alshields
Water In Door Has A Little Burst And An Instant Later Just A Trickle Of Water Into Glass. Ice Maker Making Very Small Ice Cubes. Water Good To Connection At Wall. Copper Tubing From Wall To Frig. Help !!!
#2 Posted : 15 years ago
How old is the water filter? It has to be replaced between 6 to 12 months, depends on how much water had been used.
- The water filter Part number: AP3859302
Here are the breakdown diagrams and Replacement parts for General Electric PSS26NGPAWW Refrigerator | AppliancePartsPros.com
The instructions are in the Owner's guide.
alshields
#3 Posted : 15 years ago
alshields
I tried a new water filter same problem
#4 Posted : 15 years ago
Had you drained out 2-3 gallons of water from the system after you replaced the filter?
alshields
#5 Posted : 15 years ago
alshields
the water slowed down befor I changed the filter. yes i drained out the water
#6 Posted : 15 years ago
Disconnect the dispenser water line under the freezer door at the union connector (#80 on the diagram) by pushing in the center collar while pulling out the tube. Put the end of the tube in a bucket. depress the water dispenser lever and check the water pressure out of the tube. Post the results.
alshields
#7 Posted : 15 years ago
alshields
THANKS, I GAVE UP AND CALLED GE SERVICE. THE FILTER HOLDER WAS NG ( BLOCKED) . HE ELEMINTED THE FILTER FOREVER. A NEW HOLDER WAS ABOUT $200.
WE HAVE GREAT CITY WATER !
#8 Posted : 15 years ago
You are welcome. I'm glad the problem solved and you are back in business.
