2 Pages12>
ndquale
#1 Posted : Tuesday, June 29, 2010 6:10:36 PM(UTC)
ndquale
Washing machine gets to the rinse cycle then won't move any longer. Therefore it doesn't drain and I have a tub full of water. The machine starts doing a buzzing sound and nothing happens. I do sense a minor smell similar to something rubbing. If I wait a bit and turn the dial a couple times eventually it will kick back in and finish up the rinse cycle. I've taken the front off and from a quick visual and a checking of the hoses I don't see anything. Thoughts? Thanks,
gc3p0
#2 Posted : Wednesday, June 30, 2010 10:15:30 AM(UTC)
gc3p0
does the lock door light come on??
if not it is the locking mechanism.
ndquale
#3 Posted : Wednesday, June 30, 2010 5:04:41 PM(UTC)
ndquale
There is not a locking light to look at. I did go ahead and start it back up tonight and all seemed to look fine then peeked inside on the spin cycle and it shut down completely and will not turn back on. Pull the knob and nothing.
ndquale
#4 Posted : Wednesday, June 30, 2010 5:40:18 PM(UTC)
ndquale
Started it back up but as soon as it gets to the spin cycle again it makes a long buzz and stops with water still in the tub.
gc3p0
#5 Posted : Thursday, July 1, 2010 11:17:27 AM(UTC)
gc3p0
if u can post the model # of the washer i can better get a picture of it and help you.
#6 Posted : Thursday, July 1, 2010 2:59:30 PM(UTC)
Tilt the washer back. Remove the belt and check how freely the pump pulley is moving. Post the results.
Here are the breakdown diagrams and Replacement parts for MAYTAG MAV6200AWW Washer, Atlantis | AppliancePartsPros.com
ndquale
#7 Posted : Thursday, July 1, 2010 4:05:43 PM(UTC)
ndquale
Model MAV6200AWW
Removed the belt and it freely moved with little pressure. Thanks,
#8 Posted : Thursday, July 1, 2010 7:12:39 PM(UTC)
Sounds like the problem is a bad timer.
- The timer Part number: AP4029054
ndquale
#9 Posted : Saturday, July 10, 2010 9:11:35 AM(UTC)
ndquale
Unfortunately replaced the timer and still have the same problem. The machine will stop and then if you turn the knob a tiny turn ahead it will kick back in again. Other thoughts?
#10 Posted : Saturday, July 10, 2010 7:12:42 PM(UTC)
At which point it stops and where you should move it to restart?
Guest (4)
2 Pages12>
