Thanks guys! After testing all the connections and noticing that the timer switch was not passing power through the relays, I bit the bullet and sent the switch to be repaired. I installed it today and everything fired up! Now, I have a new ignitor and a repaired switch so it should last another 10 years. I appreciate all your efforts in helping me.
You are welcome. We are glad you were able to fix it. Thank you for the feed back and good luck with your range.
