3 Pages<123
alecks
#21 Posted : Monday, June 28, 2010 6:49:02 AM(UTC)
alecks
You have to trace the air pressure hose to its other end and check it there. Probably it's got clogged.
well air clear tube was tight i fix that part.
now the washer doesn't work the cold water.when i close the hot wall fauce it start to fill cold water,if i don't close the hot wall fauce it fill hot water in every cold/cold cool/cold hot and warm .
could the new inlet valve that i installed coming bad?
or it's in another direction?
thanks gene for the advise
#22 Posted : Wednesday, June 30, 2010 2:06:20 PM(UTC)
Sorry for the delay.
Remove the wires from the water valve thermistor and see how it will work. Post the result.
alecks
#23 Posted : Saturday, July 3, 2010 6:42:02 AM(UTC)
alecks
thank you gene
i remove the wires ,and not working ,it doesn't fill.
#24 Posted : Saturday, July 3, 2010 5:55:58 PM(UTC)
Looks like the problem is a bad water temperature switch which also is a kind of auto temperature control.
- The water temperature switch Part number: AP4358828
3 Pages<123
