3 Pages123>
alecks
#1 Posted : Wednesday, June 23, 2010 5:26:59 AM(UTC)
alecks
the first problem of my washer was,not fill up the coldwater,i check in the forum and i changed the inlet valve ,now the big problem is that washer start to fill and stop that take around 10 second,i stoped and then continuos ,i did sometimes and when it's fill up it start and pass again whet it rinse.
i want to know what else it's the problem,thanks for advice.nice forum.
#2 Posted : Wednesday, June 23, 2010 1:38:21 PM(UTC)
Does it fill with cold water now?
What kind of the fill hoses are installed?
alecks
#3 Posted : Wednesday, June 23, 2010 1:46:57 PM(UTC)
alecks
thank you so much gene
well i change my inlet valve(3979346)because the coldwater no was working,i intaled my self,right now the washer start to fill and stoped,i pushed the button off and on ,and it start again,when the washer is fill up it work fine to the rinse .the washer start again.i don't know what it's wrong.
let me know if you undestand.god blees you.
#4 Posted : Wednesday, June 23, 2010 1:58:43 PM(UTC)
You did not answer my questions yet.
alecks
#5 Posted : Wednesday, June 23, 2010 2:07:43 PM(UTC)
alecks
the hoses came with the washer around year 3 months ,it's a black rubber hoses
plus right now the coldwater it's working,but the only problem it's the washer stop as soon as 8 or 10 second ,sometimes it's 20 second.
thanks
#6 Posted : Wednesday, June 23, 2010 2:30:17 PM(UTC)
Remove the wires from the thermistor on the water valve and check how it will work.
alecks
#7 Posted : Wednesday, June 23, 2010 2:58:23 PM(UTC)
alecks
well gene,before i desconect the wires i tried to start again ,and right now it's overflow ,wow .
something it's crazy .
#8 Posted : Wednesday, June 23, 2010 3:16:15 PM(UTC)
Check the air pressure hose connection the water level switch.
alecks
#9 Posted : Wednesday, June 23, 2010 3:24:03 PM(UTC)
alecks
how i do that?
#10 Posted : Wednesday, June 23, 2010 4:30:36 PM(UTC)
Open the control panel. Locate the clear plastic tube and make sure it is connected to the water level switch.
3 Pages123>
