the first problem of my washer was,not fill up the coldwater,i check in the forum and i changed the inlet valve ,now the big problem is that washer start to fill and stop that take around 10 second,i stoped and then continuos ,i did sometimes and when it's fill up it start and pass again whet it rinse. i want to know what else it's the problem,thanks for advice.nice forum.
Does it fill with cold water now?
What kind of the fill hoses are installed?
Gene. thank you so much gene well i change my inlet valve(3979346)because the coldwater no was working,i intaled my self,right now the washer start to fill and stoped,i pushed the button off and on ,and it start again,when the washer is fill up it work fine to the rinse .the washer start again.i don't know what it's wrong. let me know if you undestand.god blees you.
You did not answer my questions yet.
the hoses came with the washer around year 3 months ,it's a black rubber hoses plus right now the coldwater it's working,but the only problem it's the washer stop as soon as 8 or 10 second ,sometimes it's 20 second. thanks
Remove the wires from the thermistor on the water valve and check how it will work.
well gene,before i desconect the wires i tried to start again ,and right now it's overflow ,wow . something it's crazy .
Originally Posted by: alecks  well gene,before i desconect the wires i tried to start again ,and right now it's overflow ,wow . something it's crazy . Check the air pressure hose connection the water level switch. Gene.
Open the control panel. Locate the clear plastic tube and make sure it is connected to the water level switch.
