dishwasher does not drain completely. removed and cleaned. unit drains out of cabinet. drain line open. nothing obstructing check flapper.is pump the problem?
Originally Posted by: jerry2083 dishwasher does not drain completely. removed and cleaned. unit drains out of cabinet. drain line open. nothing obstructing check flapper.is pump the problem? I have the same problem. Replaced the drain pump. Did not fiix the problem. Suspect the controller.
Originally Posted by: gnthrush I have the same problem. Replaced the drain pump. Did not fiix the problem. Suspect the controller. Thanks wonder how u check controller?
