tjones1675
#1 Posted : Friday, June 25, 2010 10:09:34 AM(UTC)
tjones1675
My ice maker quit working I put in a new valve took the ice maker apart was able to get the motor to turn by hooking up powe no water goes into it
#2 Posted : Friday, June 25, 2010 2:15:04 PM(UTC)
You had to post your question before you took the ice maker apart. Such ice makers are not repairable and it has to be replaced after you took it apart. What was the status of the green LED on the ice maker, if you remember?
- The ice maker Part number: AP4345120
tjones1675
#3 Posted : Friday, June 25, 2010 2:26:40 PM(UTC)
tjones1675
the led light was on all the time the ice maker comes apart and you are able to replace the board inside fraom what i am told
#4 Posted : Friday, June 25, 2010 3:46:12 PM(UTC)
Originally Posted by: tjones1675 Go to Quoted Post
...the ice maker comes apart and you are able to replace the board inside...
How can you replace it if GE does not sell any parts for this ice maker?
Have you checked the water feeding tube into the ice maker? It might be frozen.
What is the exact temperature in the freezer?
tjones1675
#5 Posted : Saturday, June 26, 2010 4:42:50 AM(UTC)
tjones1675
THE FREEZER IS 0 DEGREES. WATER FLOWES THROUGH THE TUBE.iCAN GET THE MOTOR TO TURN BY HOOKING POWER TO THE TERMINAL. I JUST HAD A MOTHER BOARD REPLACED IN THE BACK AS I WAS GETTING FROST ON THE FOOD.
#6 Posted : Sunday, June 27, 2010 1:33:12 PM(UTC)
At this point I do not see any other solution, but replacing the ice maker. If it would not fix the problem, you can return it to Appliance Parts Pros. This company has very unique and friendly return policy.
Guest (6)
LG LDC24370ST Ice Maker Issues (Refrigerator & Freezer Repair)
by Guest 6/29/2024 8:55:44 AM(UTC)
Mysterious leak -Top Freezer w/Ice maker (Refrigerator & Freezer Repair)
by St.B 6/18/2024 8:40:52 AM(UTC)
Water Runs Too Long - Ice maker (Refrigerator & Freezer Repair)
by shfdyoung 6/11/2024 3:01:06 PM(UTC)
Bosch Ice Maker Dropping Ice Once Week (Refrigerator & Freezer Repair)
by Guest 5/31/2024 1:40:51 PM(UTC)
Lg ice maker leaking (Refrigerator & Freezer Repair)
by Guest 4/10/2024 2:58:55 PM(UTC)
KITCHEN AID UNDERCOUNTER ICE MAKER KUIC18NNZS0 (Refrigerator & Freezer Repair)
by kwhowell6539 3/25/2024 1:49:40 PM(UTC)
Ice maker slabbing (Refrigerator & Freezer Repair)
by Guest 3/11/2024 8:34:02 PM(UTC)
Frigidaire Freezer FPFU19F8WF4 - ice maker problem (Refrigerator & Freezer Repair)
by Eric8888 3/5/2024 11:02:19 AM(UTC)
Installing ice maker, looking for holes (Refrigerator & Freezer Repair)
by Grendel25 2/16/2024 10:02:12 AM(UTC)
ice maker in LG fridge model #LFX31925st/08 (Dishwasher Repair)
by diohabla 2/16/2024 8:36:50 AM(UTC)
Freezer holding at 22 degrees and ice maker (located in refrigerator cabin) isn't working (Refrigerator & Freezer Repair)
by eric5605 2/13/2024 4:35:48 AM(UTC)
Ice maker fiil/dump (Refrigerator & Freezer Repair)
by Guest 2/12/2024 5:46:50 AM(UTC)
GE Fridge GFE28GMKJES Ice Maker Not Working (Refrigerator & Freezer Repair)
by aopenshaw 2/9/2024 8:35:22 AM(UTC)
Ice maker issues and more? LG LFX25971 (Refrigerator & Freezer Repair)
by turtlejay 2/1/2024 5:07:00 PM(UTC)
LG French Door can the lower craft ice maker be swapped to cubed? (Refrigerator & Freezer Repair)
by Bstewart63 1/3/2024 11:45:50 AM(UTC)
