My ice maker quit working I put in a new valve took the ice maker apart was able to get the motor to turn by hooking up powe no water goes into it
You had to post your question before you took the ice maker apart. Such ice makers are not repairable and it has to be replaced after you took it apart. What was the status of the green LED on the ice maker, if you remember? - The ice maker Part number: AP4345120
the led light was on all the time the ice maker comes apart and you are able to replace the board inside fraom what i am told
Originally Posted by: tjones1675  ...the ice maker comes apart and you are able to replace the board inside... How can you replace it if GE does not sell any parts for this ice maker? Have you checked the water feeding tube into the ice maker? It might be frozen. What is the exact temperature in the freezer? Gene.
THE FREEZER IS 0 DEGREES. WATER FLOWES THROUGH THE TUBE.iCAN GET THE MOTOR TO TURN BY HOOKING POWER TO THE TERMINAL. I JUST HAD A MOTHER BOARD REPLACED IN THE BACK AS I WAS GETTING FROST ON THE FOOD.
At this point I do not see any other solution, but replacing the ice maker. If it would not fix the problem, you can return it to Appliance Parts Pros. This company has very unique and friendly return policy. Gene.
