savehailey
#1 Posted : Friday, June 18, 2010 1:22:08 PM(UTC)
savehailey
How do I replace the bake element. I got to it and removed three screws holding it down - I just don't know what it is attached to in the two holes in the back of the oven and how to disconnect it?
#2 Posted : Friday, June 18, 2010 3:31:00 PM(UTC)
The easiest way is to pull the range out of the wall and remove the rear panel. You'll have the best access from the back and from the inside of the oven at the same time.
Here are the breakdown diagrams and Cavity replacement parts for MAYTAG MER5755QAB Range - S/c F/s Ele | AppliancePartsPros.com
savehailey
#3 Posted : Thursday, June 24, 2010 4:56:31 AM(UTC)
savehailey
Thank you for your help. It was so easy to remove a small plate on the back of the oven and replace the bake element. Between replacing the keypad and the bake element myself, I saved a few hundred dollars. According to what the repairman told me it would cost for him to fix it, I could have replaced the whole oven! I should've contacted you first - then I would've saved the $86.00 walk-in-the-door fee. And, it felt good to accomplish this myself!
#4 Posted : Thursday, June 24, 2010 8:32:25 PM(UTC)
You are welcome. I'm glad you were able to fix it.
Guest (4)
Replace bake element on electric range/oven (Oven Repair (including Ranges and Cooktops))
by bad Dog 2/24/2019 9:17:21 AM(UTC)
replace bake element (Oven Repair (including Ranges and Cooktops))
by Earwicker 10/22/2015 8:41:41 AM(UTC)
Replace Bake Element, Remove Oven Bottom (Oven Repair (including Ranges and Cooktops))
by jcarbeck 1/6/2010 6:44:45 AM(UTC)
how to replace bake element (Oven Repair (including Ranges and Cooktops))
by moult2850 12/2/2009 12:20:48 PM(UTC)
replace bake element; doesn't heat up (Oven Repair (including Ranges and Cooktops))
by jpatch3 7/6/2009 6:06:48 PM(UTC)
Replace Bake Element-Whirlpool self-cleaning oven (Oven Repair (including Ranges and Cooktops))
by rpettet 6/21/2009 12:12:25 PM(UTC)
How do I replace bake element (Oven Repair (including Ranges and Cooktops))
by csonka 5/7/2009 1:58:41 PM(UTC)
Just replace bake element takes more than 30 minutes to heat (Oven Repair (including Ranges and Cooktops))
by AandRelectric 5/5/2009 10:12:26 AM(UTC)
Remove & replace bake element (Oven Repair (including Ranges and Cooktops))
by Suzipat 4/30/2009 6:52:02 AM(UTC)
MAytag performa replace bake element (Oven Repair (including Ranges and Cooktops))
by bacrath 5/5/2008 6:03:35 PM(UTC)
How to replace Bake element? (Oven Repair (including Ranges and Cooktops))
by patchas 12/27/2007 5:10:33 PM(UTC)
