Janielynn
#1 Posted : Tuesday, June 15, 2010 9:00:47 AM(UTC)
Janielynn
Is there a way to repair my leaking water dispenser?:confused:
#2 Posted : Tuesday, June 15, 2010 12:48:21 PM(UTC)
Can you be more specific on the problem please?
Janielynn
#3 Posted : Tuesday, June 15, 2010 2:26:32 PM(UTC)
Janielynn
The water dispenser constantly drips. It more than fills a glass overnight, causing water to overfill the tray under the dispenser and run down the front of the refrigerator. Otherwise ice maker and water dispenser both
work fine.
Janielynn
#4 Posted : Thursday, June 17, 2010 5:53:27 AM(UTC)
Janielynn
Gene: I hope you can give me some info. My GE fridge water dispenser is dripping constantly. Otherwise ice maker & water dispenser is working fine. Thanks for any help you may be able to offer.
esm2010
#5 Posted : Tuesday, June 29, 2010 8:14:31 AM(UTC)
esm2010
is there a way to repair my leaking water dispenser of Kenmore refrigerator Model # 253-51399104?
#6 Posted : Wednesday, June 30, 2010 1:26:29 PM(UTC)
Janielynn,
Sorry for the delay.
Have you replaced the water filter recently?
If not, then the problem most likely is a bad water inlet valve on the back of the refrigerator (#800 on the diagram).
- The water inlet valve Part number: AP3192626
#7 Posted : Wednesday, June 30, 2010 1:27:56 PM(UTC)
Is it really leaking or it's just dripping water?
Guest (5)
