Is there a way to repair my leaking water dispenser?:confused:
Can you be more specific on the problem please?
The water dispenser constantly drips. It more than fills a glass overnight, causing water to overfill the tray under the dispenser and run down the front of the refrigerator. Otherwise ice maker and water dispenser both work fine.
Originally Posted by: Gene  Can you be more specific on the problem please?
Gene. Gene: I hope you can give me some info. My GE fridge water dispenser is dripping constantly. Otherwise ice maker & water dispenser is working fine. Thanks for any help you may be able to offer.
Originally Posted by: Janielynn  Is there a way to repair my leaking water dispenser?:confused: is there a way to repair my leaking water dispenser of Kenmore refrigerator Model # 253-51399104?
Janielynn, Sorry for the delay. Have you replaced the water filter recently? If not, then the problem most likely is a bad water inlet valve on the back of the refrigerator (#800 on the diagram). - The water inlet valve Part number: AP3192626
Originally Posted by: esm2010  is there a way to repair my leaking water dispenser of Kenmore refrigerator Model # 253-51399104? Is it really leaking or it's just dripping water? Gene.
