surfside
#1 Posted : Monday, June 14, 2010 9:46:00 AM(UTC)
surfside
The frig section was warm. The damper was closed. I took the damper out and let it run over night. The freezer was at set point 4 degrees. The frig was 30. How can I tell if I have a bad damper, board or sensor?
#2 Posted : Monday, June 14, 2010 12:12:26 PM(UTC)
If the damper door moves and is not busted from the motor, it's probably ok. I would replace the fresh food thermisters. Usually two, maybe only one. Check your service sheet to confirm. If that fails to fix it, replace the motherboard in the back. You can get your part #'s from this parts site.
surfside
#3 Posted : Monday, June 14, 2010 4:57:54 PM(UTC)
surfside
I checked the vdc at the plug in to the damper motor. There is no change in voltage at any set point. The digital read outs seems to be accurate for the freezer and frig. Would you still suspect a sensor problem or the mother board only?
#4 Posted : Tuesday, June 15, 2010 1:04:44 AM(UTC)
That is a digital system, damper is pulsed open, then closed, not an analog system. I would replace items as mentioned, but I must agree it seems like a bad motherboard unless one thermistor is way off value.
Freezer working, refrigerator warm (Refrigerator & Freezer Repair)
by Hero 12/31/2021 6:48:52 AM(UTC)
Refrigerator warm 45 degrees , freezer gets very cold then warms up (Refrigerator & Freezer Repair)
by sgordonson 9/25/2020 7:31:42 AM(UTC)
Refrigerator warm, freezer cold, frost buildup on back of freezer (Refrigerator & Freezer Repair)
by Geoff Hess 8/15/2017 8:31:32 AM(UTC)
Frigidair refrigerator freezer cold refrigerator warm. (Refrigerator & Freezer Repair)
by Dennypccc1 9/7/2016 6:50:59 PM(UTC)
Electrolux - refrigerator warm - freezer good - cooling drawer good (Refrigerator & Freezer Repair)
by smnorrick 2/5/2016 11:22:03 AM(UTC)
Refrigerator warm and cold (Refrigerator & Freezer Repair)
by David T 7/16/2015 10:29:23 AM(UTC)
Freezer defrosts and refrigerator warms (Refrigerator & Freezer Repair)
by problems 11/10/2014 4:40:42 PM(UTC)
Freezer Cold Refrigerator Warm - Evap Fan Runs Intermittently (Refrigerator & Freezer Repair)
by Mkorns 5/27/2014 10:52:33 AM(UTC)
Refrigerator Warm / Freezer Cold (Refrigerator & Freezer Repair)
by lukewarm 11/1/2013 9:21:13 AM(UTC)
GE Freezer and refrigerator warm, frost on coils-what should an amateur change first? (Refrigerator & Freezer Repair)
by dfavelo 10/2/2013 6:55:19 PM(UTC)
Freezer seems fine, refrigerator warm, found frost on return vent at top (Refrigerator & Freezer Repair)
by Cczkcb 10/1/2013 2:42:34 AM(UTC)
Refrigerator warm Freezer ok (Refrigerator & Freezer Repair)
by larbear 8/24/2013 7:24:21 PM(UTC)
Refrigerator Warm Light not working (Refrigerator & Freezer Repair)
by blueeyes243 4/15/2013 7:07:22 AM(UTC)
Refrigerator warm, coils frozen solid (Refrigerator & Freezer Repair)
by tom1799 9/12/2012 8:13:10 AM(UTC)
Refrigerator warm, freezer fine. (Refrigerator & Freezer Repair)
by gandswalton 9/2/2012 1:34:35 PM(UTC)
