techdowe
#1 Posted : Thursday, May 29, 2008 3:09:19 AM(UTC)
techdowe
Problem: No Heat :eek:
Dryer does turn on and tumble.
Timer does not advance during timed dry or automatic dry.
I have tried it with the venting disconnected.
I have verified that the outlet has 240 VAC.
Heater circuit never gets 240 VAC.
What I think is the Thermal cutoff "non resettable" has continuity.
As I understand it the timer will not advance in auto dry if the clothes are not getting dry.
Should this timer advance in timed dry ?
#2 Posted : Thursday, May 29, 2008 8:30:19 PM(UTC)
If your dryer is less than a year old, it should be under the manufacturer warranty. Do not do anything and call Amana for service.
Dryer Not Heating At All (Dryer Repair)
by ross endriga 11/24/2008 3:39:40 PM(UTC)
