Suddenly, it is not producing heat at all, although all the others like air fluffing and motor is rotating well and switches are working fine. :(
Probably the heating element. If the fuse was blown it would not run at all.
Not totally true. If the breaker is partially tripped the dryer will run, but won't heat. Go and flip the breaker off and on for the dryer a few times, and then try the dryer. If it still does not heat. Take the plate off where cord comes into the dryer, and those dryers are good for the wires being burn't at the terminal block. If everything is fine there. Then the element will most likely be the issue. Tom ApplianceEducator.com
