I have a old maytag 2 speed washer- the water will drain but it will not spin. It does agitate. It smells like something is burning if you let it stay in the spin cycle. what could the problem be?
a ge washer will not spin.
For the Maytag washer, probably something stuck in the tub. Just tilt back the top, remove tub cover and look. Post results.
i have a kitchen aid washer(#kaws850jq0)-the spin cycle does not work-i can hear the motor running but the washer does not spin
Originally Posted by: robert59 i have a kitchen aid washer(#kaws850jq0)-the spin cycle does not work-i can hear the motor running but the washer does not spin i have a kitchen aid washer(#kaws850jq0)-the spin cycle does not work-i can hear the motor running but it won't spin
For the GE and Kitchen aid persons, use a new posting with make and model #
