wknd_warrior
#1 Posted : Thursday, June 3, 2010 10:22:08 AM(UTC)
wknd_warrior
There is a small rust hole in the outer tub located directly on top of one of the pressure points of the baseplate. Looks like the 1 of 7 friction gaskets moved out of place allowing the outer tub and the baseplate pressure point to rub together causing the hole.
Can the tanks be repaired? Since there already exists a hole in the outer tub, I could drill a hole through the baseplate. Then, install a rubber washer and bolt similar to the 4 bolts and rubber washers that are used to attach the outer tub to the baseplate.
Or, maybe weld a patch. But then rust is a concern.
Any ideas?
Thank you
#2 Posted : Thursday, June 3, 2010 2:55:39 PM(UTC)
You can try to use an epoxy two part putty together with an aluminum self adhesive tape.
