ronhinshaw
#1 Posted : Saturday, May 15, 2010 6:58:43 AM(UTC)
ronhinshaw
When I start a cycle it runs for about 10 seconds then stops
sidfink43
#2 Posted : Monday, May 17, 2010 10:33:36 AM(UTC)
sidfink43
It could be several expensive things like the control board, but before doing anything check the lid switch. By pass it and see if things improve. If not you will have to try replacing the control board. If it is not the control board then under certain circumstances you can return it if you order from this site.
ronhinshaw
#3 Posted : Saturday, May 29, 2010 4:20:13 AM(UTC)
ronhinshaw
Wasnt switch, checked that first. Found a used controll board on ******** for $40.00. Did the trick, thanks sidfink 43.
sidfink43
#4 Posted : Saturday, May 29, 2010 4:30:59 PM(UTC)
sidfink43
Great, glad you got an inexpensive part and got it fixed, and thanks for the update.
Vintage Maytag washer A612 motor replacement - possible to use single speed motor? (Washer Repair)
by mookie3333 5/3/2024 5:58:32 PM(UTC)
Maytag washer mav6257aww user (Washer Repair)
by Bigredkansan 4/5/2024 6:17:18 PM(UTC)
Maytag washer mav6257aww (Washer Repair)
by Guest 4/5/2024 6:11:48 PM(UTC)
Clicking / creaky sound Maytag Washer (Washer Repair)
by Guest 4/1/2024 7:29:31 AM(UTC)
Maytag Washer Doesn't Complete Spin Cycle (Washer Repair)
by glmoore0001 2/5/2024 6:32:24 AM(UTC)
Maytag Washer MVWP575GW0 strange problem (Washer Repair)
by Macdawgg 11/18/2023 8:07:47 AM(UTC)
Maytag Washer Excess Suds during "clean washer" cycle (Washer Repair)
by DogHair 11/14/2023 2:04:58 PM(UTC)
Top load Maytag washer model Model LA410 with s/n 336623 (Washer Repair)
by Guest 10/26/2023 10:58:17 AM(UTC)
Maytag Washer MAH5500BWQ (Washer Repair)
by Guest 9/10/2023 4:01:49 PM(UTC)
MAYTAG WASHER MODEL MAH5500BWW (Washer Repair)
by Guest 8/21/2023 5:22:03 PM(UTC)
Maytag washer drive motor mount question (Washer Repair)
by Guest 7/29/2023 5:24:40 AM(UTC)
Maytag Washer Rise Cycle (Washer Repair)
by Ollie21 7/5/2023 6:03:49 PM(UTC)
Maytag washer control board burns out (Washer Repair)
by Guest 6/20/2023 2:12:48 PM(UTC)
Maytag Washer Not Draining F9E1 (Washer Repair)
by amappliancewi 6/16/2023 10:44:24 AM(UTC)
MAYTAG WASHER NO GOING INTO SPIN CYCLE (Washer Repair)
by Guest 2/27/2023 8:13:04 AM(UTC)
