When I start a cycle it runs for about 10 seconds then stops
It could be several expensive things like the control board, but before doing anything check the lid switch. By pass it and see if things improve. If not you will have to try replacing the control board. If it is not the control board then under certain circumstances you can return it if you order from this site.
Wasnt switch, checked that first. Found a used controll board on ******** for $40.00. Did the trick, thanks sidfink 43.
Great, glad you got an inexpensive part and got it fixed, and thanks for the update.
