relayer13
#1 Posted : Thursday, May 20, 2010 11:19:53 AM(UTC)
relayer13
I have a Kenmore 363.9701711 which is made by GE. Originally I was getting no water to the ice maker. I replaced the water inlet valve. After that water was going to the icemaker but would not shut off. I replaced the ice maker thinking that may be the problem. Still water will not shut off to the ice maker. Any further help would be appreciated.
taylorcj
#2 Posted : Friday, May 21, 2010 8:17:36 AM(UTC)
taylorcj
I just replaced the inlet water valve and that did not solve my problem.
I was thinking it was the timer and was cotemplating of replacing the ice maker. sounds like that did not solve your problem. Any help would be greatly appreciated. my timer doesn't seem to be turning inside the freezer
#3 Posted : Friday, May 21, 2010 1:46:06 PM(UTC)
Have you replaced the ice maker with a brand new? What is the part number of the new ice maker?
Would the water shut off if you turn off the ice maker?
Would the water shut off if you remove the wires from the water inlet valve?
#4 Posted : Friday, May 21, 2010 1:48:03 PM(UTC)
What is the complete model number of the refrigerator?
What was the original problem?
Which timer did you mean?
taylorcj
#5 Posted : Friday, May 21, 2010 5:15:30 PM(UTC)
taylorcj
The Model is FRS26R4CB6
Original problem overflows when refilling
Is there a timer on this icemaker :confused:
relayer13
#6 Posted : Saturday, May 22, 2010 2:41:58 AM(UTC)
relayer13
The new ice maker is Replacement Ice Maker Kit for GE Refrigerator/Freezers (RIM300).
Actually when I dissconnected wires from the inlet valve the water still runs to the ice maker. At no time is it a stream of water, the water runs slow almost a fast drip.
taylorcj
#7 Posted : Sunday, May 23, 2010 10:15:08 AM(UTC)
taylorcj
Does anyone know the next step to take in fixing my icemaker I'm getting water but just want shut off. Is it stuck in the fill mode or somethig else?:confused:
#8 Posted : Sunday, May 23, 2010 7:32:57 PM(UTC)
Sounds like the problem is a bad water inlet valve which does not close all the way. Did you use the OEM part as a replacement?
- The water inlet valve Part number: AP3189335
relayer13
#9 Posted : Monday, May 24, 2010 3:27:48 AM(UTC)
relayer13
Yes, thats the part I used, possibly its defective?
#10 Posted : Monday, May 24, 2010 8:36:31 PM(UTC)
I do not see anything else what could cause it.
