Washer was placed, leveled and started a load. Apparently, it wasn't leveled good enough as when it hit fast rinse, it started walking across the floor. It apparently, it wasn't level enough and wouldn't spin from then on. I have inspected the belt system and found the belt twisted and wrapped around the large drum beside it. I am having trouble finding out hoe the belt fits back of what pulleys, etc. Do you have a diagram that I may download or look at? Thank you
Your model comes up as a direct drive machine which means there is no belt, so we are not sure exactly what parts you are describing.
