AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
whirlpool dryer works but timer dosen't advance
Dryer dryes fine but does not turn off. The knob stays where you set it when you start it. Changed the timer but that didn't fix problem.
Didn't try timed operation.
Originally Posted by: glassman58  Didn't try timed operation. Can you try and post the results? Gene.
As your dryer is not turning off, I would contact Whirlpool directly at 1-866-698-2538.
I cleaned the dryer then tried it again. Noticed the burner comes on when you first put the clothes in and turn it on. Then as the clothes start drying the igniter comes on but the burner does not light. Could this be a bad coil on the gas valve? Any sugestions.
Originally Posted by: glassman58  I cleaned the dryer then tried it again. Noticed the burner comes on when you first put the clothes in and turn it on. Then as the clothes start drying the igniter comes on but the burner does not light. Could this be a bad coil on the gas valve? Any sugestions. Most likely the problem is a bad gas valve coils. Gene.
I ordered the gas valve coils hope this fixes the problem.
Dryer Repair
