Robert, Looks like the touch pad gone bad too. - The part number for the touch pad (aka membrane switch) is AP368491 Gene.
Originally Posted by: Gene Robert, Looks like the touch pad gone bad too. - The part number for the touch pad (aka membrane switch) is AP368491 Gene. Thanks Gene. Bob
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Originally Posted by: robert22 Please click one of the Quick Reply icons in the posts above to activate Quick Reply. Gene, I received the new touch pad (membrane) today and installed it. It works great. Everything is back to normal. Thanks again for your help. Regards, Bob
Bob,
I'm glad you were able to fix it.
Hi Gene, I have a jenn air stove. I just ordered and replaced the electronic display. At first it seemed to work fine, however the "0" would not work. I disassembled and tryed to clean the membrane ribbon connection with scotchbrite. Now nothing except the timer works. This pad did seem to work fine before I did anything. Does the membrane need to be replaced, or is it possible that the ribbon connection may need to be cleaned with something like contact cleaner?
